I tore apart a transfer case I had that went bad a few months ago with some time off from work and school. Once I got inside it I found that the needle bearings that the input shaft of the tcase rides on let go and those needle bearings tore up the inside of the case with metal shavings everywhere. It also scored this bearing surface really bad where that annulus hub (planetary gear looking thing) rides
Can I still use this case if I can do something about the scored surface? Also any recommendations?
