NP208, clocking ring and adapters- CO
cwn anwyn
Falcon CO
I'm putting my rig back together (finally :doah:) and have these parts laying around. Maybe someone could use them.:waytogo:
NP208, 27 spline input, slip shaft output. SOLD
Also have a Dodge NP208 that I intended on using the fixed rear output on the GM case as a home brew SYE: NP205 is gone!
NP208 clocking ring. Made by Great Lakes Offroad.
NP208 to 700R4 tall adapter.
NP208 or NP241 to 700R4 short adapter.
I'll get some pics up as soon as I get things organized and cleaned up a bit.
Shoot me a pm if there is something that you can use.:thumb:
Z
Updated parts and prices
Finally sold the NP208 to a guy over in Rifle I think. He wanted it for a upcoming adapter project he's working on. Trying to make a 5 bolt to 6 bolt adapter to put the 208 behind a NV3500 I think he said.
Anyway, I still have the following parts that need to find a home:
Dodge NP208 output shaft and tail cone. I took apart the cracked Dodge case and pulled the output and tail cone and bagged up the small parts. Perfect for your home brew SYE project. $50.00
NP208 clocking ring. Made by Great Lakes Offroad. SOLD
NP208 to 700R4 tall adapter. $25.00
NP208 or NP241 to 700R4 short adapter. $25.00
Stock 700R4/NP208 cross member from my 84 K5. $10.00
Or I'll take $140.00 for all of it if someone could use all the parts.
Z
Are those the only parts you really need to do the swap? The cone and the output?
According to this write up that is all that is needed. I was originally going to swap the case halves but figured on going this route since I can't weld the aluminum bungs and the Dodge case I had was cracked/broken on the bottom. This way looked fairly easy to other than tapping the GM case.:waytogo:
Z
