broncoman6524
yes i know a hundred times repeated...ive searched and from what im reading just pull off the nut, remove yoke, pull out seal, and check yoke for wear...then there is a "rubber o-ring"
what is that? is it only on some models of 208s or did i mistake that from some 205 thread about it that i read
then just put it all back together and torque the nut to 150ft/lbs.
yes? no? i just dont wann tear into this and be like F*ck what did i do?
