I just magically resolved my own issue. 208 rear output. It leaves a drop at the base of the seal, as if it seaps, not leaks, then eventually drips.
In all honesty, I have no idea what the differences in seal brands are - But, I do know my own no longer leaks after switching brands on the
fifth replacement.
I had suggestions of checking the shaft bearing for play - Which would give the shaft minimal slop and therefore seap on the seal's edge, checking for grooves, balancing the shaft and such. Nothing fit the bill.
I previously took my seals from
Advance Auto and
O'Reilly's. This last one, which I replaced for GP when I had the transmis/fer pack down for a rear main leak - hasnt leaked yet. I was past trying to seal it up actually, until I had everything else dried up.
Now, my drive is spotless.
The seal is a Timken brand, found at Autozone. Hopefully, you havent been there yet.
Hope this helps
Troy B
Ft Hood, TX
