Does anybody know off-hand how much the rear output shaft sticks out from the case on the 208 t-case. I can't get a measurement right now and can't find the info online. Thanks
I have one in my garage that I had taken apart to rebuild, but found an 89' 241. So the 208 was just slapped back together to get it out of the way.
I measured 15/16" from back of housing to end of shaft. It would be better if someone else can confirm this because it's been about 4 years since it was messed with.
Thanks guys. I just picked up my cv shaft and the guy put a different slip yoke on that doesn't spline to the end. It actually only splines about 1/2 way up the slip yoke. Not sure if that will work, but about to find out.
