socalmudtrucker
Registered Member
I have an '87 Burb 4X with a 350/TH700/NP208 and 6in lift. She has no problem
staying in 2Hi or 4Hi for the most part but when I put her in 4Lo
she wants to slip out with any little bump and goes right to
neutral.
After some grinding and frustration I can get her back
in gear. Shift fork? Rebuild needed(cost?) linkage? In addition
when shes cold under acceleration she will go as usual but from
2nd to 3rd goes to neutral for a second and then on like nothing
happened. After warm up is fine. Anyone with opinion or similar
experience? Thank you.
neutral.
After some grinding and frustration I can get her back in gear. Shift fork? Rebuild needed(cost?) linkage? In addition
