NP208 shifter lift
weaksauce
Newbie
Texas
SO...
Clocking my NP208, with the ORD ring to the max. Going for the flattest belly possible (on the blazer ;)
Read about some issues with popping out of 4lo clocked fully up and under full load. Also read about raising the shifter up to correct the geometry (mrk5)
http://coloradok5.com/forums/showthread.php?t=172623
If anyone else has done this, how many inches have you raised it? I will be doing experiments next few days off, so if no one knows I will post what I find. Pics if you want 'em.
Story: Tranny fluid leaks out the wazoo. Taking everything apart to replace all the seals. While I'm at it, clock the Tcase up and make a new Xmember, and add a +2 qt tranny pan. The Bad: rerouting exhaust that I've already custom made for the truck. :(
Sub'd for the info:popcorn:
I will be doing the same thing shortly also.
(side note) your user name was my nickname all through school:doah:
*note I am 6'2" and 250lbs
