NP208 Tailhousing removal
Hossbaby50
3/4 ton status
Peoria, AZ
I picked up a used 208 to replace mine. The new case has a piece cracked out of the rear tailhousing where the rear seal goes. I want to swap my old tailhousing onto this new case. I removed the bolts for on the new case, but can't get the rear housing off.
I can't get anything into the joint to pry it off (also affraid I will crack the aluminum). I am also affaid to heat the housing because of the plastic parts inside the tailhousing. How should I go about getting of the old tailhousing? Thanks for any input.
Harley
I did remove the speedo gear. My problem is I can't get anything in the crack to pop the case open. it is sealed with RTV and the gap is to small to get anything into. Sorry, I should have mentioned that.
Harley
I'm trying to remember. Don't think anything came off the shaft....Hmmm, did ya get all the bolts off?
It's been awhile since I took mine off and don't remember having any trouble.
I gently tap on the fins with a hammer to get the tail housing to spin a bit. Then it comes right off. I have not broke one yet.
id reccomend a rubber or rawhyde hammer, steel banging on aluminum might have some consiquenses. /forums/images/graemlins/thinking.gif
