I'm doing a driveway build on an '83 K5, I have to swap my transfer case from passenger side to the drivers side to run the front. I'm trading my NP208 for an NP241 with a mechanical shift lever. As far as I know the adapters should be the same, and bolt right up so long as I get a 27 spline input shaft (I'm running a TH350).
My question this time is about the speedometer. Is there a simple solution to converting the truck to an electric speedometer or converting the Tcase to run a mechanical speedometer (cable). I have read (for what that is worth) that you can remove the plug in on the case and just screw in the cable. But I've never tied and don't yet have the case to look at, other than this one picture.
If that's not possible and turns out to be your typical internet mechanic advise, is there an electric speedometer that will fit my cluster? Or should I just forget about having a speedo with that TCase?
