np208 to np241 swap
michael0584
houston texas
My 208 is dying and I was given a 241. I've been told its a direct swap but I'm missing a few pieces and didn't know if they interchange. Its missing the rear yoke and the shift linkage, It is a mechanical speedo version. Will my shift linkage, rear yoke, skid plate, and support rod fit off my 208? Also will the driveshafts be the same length?
Absolute direct swap. EVERYTHING you mentioned will work with the 241. Now, i'm assuming the 241 came from the same trans type as your 208 (same input spline count).
