It's been a while since I opened one myself but they remind me of keys to go in between the two case halves, to secure them together.Hi guys.
I cracked open an NP208c that i just bought, and these fell out immediately. I can't see them in the parts diagram. Anybody know what they are and where they go ?
Thank you. I see, (on the curved side) what looks like wear marks ?It's been a while since I opened one myself but they remind me of keys to go in between the two case halves, to secure them together.
If you don't get a response soon I will be taking one apart in the coming days
They wouldn't be some type of chain tensioner?Thank you. I see, (on the curved side) what looks like wear marks ?
Can you see em in the pic ?
The wear marks look like the shifter rail is ramping up on it?Thank you. I see, (on the curved side) what looks like wear marks ?
I've tried to fit them into and around the selector cam but no bueno.The wear marks look like the shifter rail is ramping up on it?
I should have time to take one apart next Monday or Tuesday if no one else chimes in
Is the box (23) the planetary and planetary carrier ?It's a "syncro key". They're part of assembly 23 below. Those snap rings are kind of like springs that hold them out, but let them push in for the collar to go over them. Those may be broken or missing. I'm not sure what the symptom would be, other than it wouldn't quite lock in place.
Thank you Blue85 for identifying those parts !!Those are indeed the syncro keys, or syncro struts as another diagram refers to them. The planetary was locked to the planetary carrier and when I disassembled, i discoveed chunks of metal locking the gears together. Now i see there are supposed to be 3 syncro keys/struts, but i only found 2. The magnet was loaded with needle bearings and race material. What a basket case.![]()
I have a few np208c tcases, if you need parts let me knowThank you Blue85 for identifying those parts !!![]()
I have no doubt I will need parts.I have a few np208c tcases, if you need parts let me kn I
I will see how much it is for shipping something this long first.I was just looking st the mainshaft pic i took, and noticed another needle bearing next to the selector spring. I'm wondering if i should even bother to go through the mainshaft. What would you need for a complete mainshaft ?
If someone is going to blazer bash I could send the whole thing but,I don't know the conditions since they came off trucks I parted.Honestly 208’s are a dime a dozen. I’d find a better one that hasnt had metal run through it.
I may do that, ive pressed bearings into the case, but the internals are all i need.Honestly 208’s are a dime a dozen. I’d find a better one that hasnt had metal run through it.
By the way, 32 spline or 27 spline input?I may do that, ive pressed bearings into the case, but the internals are all i need.
