chris85 1/2 ton status Premium Joined May 16, 2006 Posts 1,320 Reaction score 1,225 Location vicksburg, mississippi Dec 30, 2017 #1 Decided to go another way in my build. ‘89 np241 mechanical speedo. Swapped in a 32 spline input shaft but I do have the original 27. ORD SYE and HAD 1350 cv flange. $650 Also have the original front driveshaft if wanted. $30 Adapter not included
chris85 1/2 ton status Premium Joined May 16, 2006 Posts 1,320 Reaction score 1,225 Location vicksburg, mississippi Jan 25, 2018 #2 Dropping the price to $550 bc I realized I can use the flange on my 205(keeping it). Comes with a u joint yoke now.
chris85 1/2 ton status Premium Joined May 16, 2006 Posts 1,320 Reaction score 1,225 Location vicksburg, mississippi Feb 18, 2018 #3 Bump
Bent77 I am CK5 GMOTM Winner Joined Dec 3, 2002 Posts 48,156 Reaction score 85,135 Location Nunya Feb 18, 2018 #4 @Babaganoosh
chris85 1/2 ton status Premium Joined May 16, 2006 Posts 1,320 Reaction score 1,225 Location vicksburg, mississippi Feb 18, 2018 #5 Bent77 said: @Babaganoosh Click to expand... Hence the bump
Babaganoosh 1 ton status Premium GMOTM Winner Joined May 30, 2007 Posts 18,495 Reaction score 12,973 Location Phoenix Arizona Feb 18, 2018 #6 You guys are mean. I need the vss sense one unfortunately.
chris85 1/2 ton status Premium Joined May 16, 2006 Posts 1,320 Reaction score 1,225 Location vicksburg, mississippi Feb 18, 2018 #7 Can’t you swap the housings out? Not trying to talk you into buying mine, but I’m pretty sure it’s been done. Found it. Just in case https://ck5.com/forums/threads/conv...-electronic-speedo-long-write-up-pics.296187/
