Np241 extension housing
JpEater
Augusta, Georgia
I am looking for a Pass drop 89-91 241c extension housing. I need part that bolts to the back half of the case (speed sensor screws into this part i need) not the tail shaft/slip portion. Anyone know where I can find one? I have been told that they are discontinued at the dealer.
Trey
If it's for the speed sensor then it will be 90-91 only. 1989 was mechanical speedo.
NP 241c
I just recently bought a NP 241 passenger drop transfer case that has the screw in speed sensor but it wont work for me. I need the one with the mechanical speedometer Does anyone have the Mechanical Speedometer from an 1989?
Would I have removed that part during a slip yoke eliminator install? If so, I saved all those parts but don't need them. Send me photo and I'll look to see if I got it.
The part he needs bolts directly to the case and when doing a SYE this piece gets used still but the back tail housing does not.
I am pretty sure I have one. It will need a new bearing. Shoot me a pm with a offer if your interested.
I think i have found one. I will know in a couple of days. If not I will be sending some PM's.
Trey
If it is the same as a drivers drop housing, I think it is,then I have one. Let me know..
Yea, mines a passenger side drop transfer case and it needs to be a Mechanical speedo setup. Not the ESS( electronic speed sensor).
The one that I would need would be out of a 1989 cause 1990 started the speed sensor. 1989 was he last yr out for the mechanical speedo.
