NP241 Front Seal
trustyrusty
Registered Member
Florida
Went to replace the front seal on my 91 K5 as it was transferring fluid as fast as I could put it in transmission.
Example: Put fresh fluid in both to proper levels and went 5 miles on interstate and it was blowing out the tcase vent. Checked trans and no fluid on stick...:frown1:
Anyhow, Bloody knuckles and grease up to my shoulders later I have it out and there was no input seal :dunno:WTF. Looked on the trans shaft and there it was:thinking:
Something was obviously not right. I removed the front bearing cover and there was the remnants of the old seal still pressed in it.
The red seal was on the trans and is a National #3173 which is the correct (albeit less desirable) seal.
Pressed it out and began inspecting the situation.. From what I could figure, someone was:smokin2: some serious stuff when they did this. The seal that was on the trans output shaft looked like the edge was crushed so it would fit into the leftover part of the original seal that was still in the tcase. See Pics.
Now I'm scared what else the might have hacked in there.
I put a new double lip seal in there and all looks fine in that respect.
Question... Did the factory use gray silicone when assembling the case halves and also the rear output snorkel? or were there gaskets?
I haven’t had any other problems with the tcase so I don't want to do a rebuild if I don't have to, and really cannot afford to at this time.
p11DY5EDj
p9AYBIPAj
p51WRoJAj
lol, leaving the old seal in would certainly cause some leaking.
I rebuilt mine not that long ago. I was told no gasket between the halves. No leaks so far.
Ya Think...
Got her put back in all seams fine (short run around the block. Time will tell.
But I found another problem......
Front diff has about 1/4 inch of backlash:eek:
Story of my life, fix 1 thing and 3 more pop up. Gonna leave it as is for now and stay in 2wd till I can afford to fix it.
