This is for the '89-91 drivers side drop cases. If there is any difference.
Looking at Rockauto, the input seal applications seem...optimistic.
Just narrowing it down, for a 1990 K5, I see two Timken part numbers for the seal: 710928 and 3173
Between those two part numbers, the only information given that is different is the specs on one, and cross reference part numbers. Warranty is the same, general description is identical. Here is the link to the 710928 number if it matters: Rockauto 710928
But if I click application, one says K5 '73-04, the other says K5 '87-94. Obviously those are some weird year splits, one would supposedly fit four different t-cases but the other three?
Anyway, having dealt with this for an axle seal before (same supposed application, one manufacturers part fit, the other did not), and since I'll be on a tight timeline, is there any general advice as to what seal is known to work? I'm ok without Timken, National and USA Standard Gear are listed (Although USA being about 1/4 the cost of the others causes concern) but if anyone knows for sure a part number that works, I'll go that route. Doesn't have to be Rockauto, I just use them to check things because they have pretty extensive listings.
