NP241 or a 208?
91 full size jimmy
NH
:confused: i have a 241 in my jimmy and i bought an 87 K5 blazer. Whad do i need to do to take the tranny and tcase out of the 87 and put it in mine?
If any one needs parts let me know and ill see if they are good and if they are there. email me at [email protected]
it need all new gaskets. some one had it apart before i got it . I put 90 wate in it and in about 25 miles it was empty. i wanna rebuild the 241 and put it back in if its all good and sell the 208
You should probably reseal the 241 and use it. The drivetrain will swap in directly without any mods but your speedo won't work properly. The 241 is an electric speedo and the 208 is a mechanical speedo.
The electric vs. mechanical speedo is the only problem I see with the 2 drivetrain swaps. The 241 and 208 are interchangeable except for the 241's with the electric speedo setup.
Harley
i know that it needs to run with ATF but i was tryen to keep something init to keep it lubed up
I think the 241 came with elctrtical and mechanical speedo. Just finished rebuilding mine, and it wasnt to hard except that it laid on the bench for 3 months apart while i waited on the short tail shaft kit to arrive. I only used rtv and it worked great
Both cases are good units. I personally would reseal the 241 and install a fixed yoke, short shaft kit. The 241 needs the thinner ATF because it has an oil pump in it and the gear oil is too thick to pump around. The cases are pretty simple to take apart and reseal. Even if you are not comfy doing it yourself, just pull the unit and bring it to a shop. They would probably only charge you about 100-150 to do it.
Better hope none of that gear lube made it way into the 700R4. If it did gear lube will toast a auto tranny. Thats why they use ATF in a xfrer case mated to a auto tranny. Might be a good idea to change your tranny fluid ASAP
where can i get a gasket kit and a fixed yoke, short shaft kit?:confused:
The only gasket per say is where the extension housing bolts to the rear case half. Then there are three seals, one at each input and output shaft, and the rest is RTV silicone. When using the RTV only use as much as is needed. Don't overdo it. A little silicone goes a long way. One tube is more then enough. As far as tools go, the only special tool I would reccommend having is a good set of snap ring pliers. Other then that everything is normal stuff. Check with some of the vendors on here about where to get the slip yoke eliminator kit. I know I have seen them advertised on here before.
