Np241 questions
white90burb
Chesapeake VA
In my 75 blazer I'm running a tbi 350 with a 4l80 and a 241. In the future I'm wanting to add the sye kit and clock it flat. I did some searching and found some clearance issues with dual exhaust and clocked 241s. I'm getting ready to do exhaust on my rig right now and don't want to have to redo it later. I'm planning on long tube headers and single 3 inch down the drivers side. Has anyone done this set up with a clocked tcase?
Also what are you guys doing for tcase shifters once you clock your 241? Does anyone make a cable shift set up?
i have seen some guys modify the linkage due the new angle. some others use bearing rod ends for this.
Guess this thread is dead, but I have a similar question regarding the linkage
