NP241 sensor and trigger wheel
thatK30guy
1 ton status
Anyone got a 241 laying around thats junk or in pieces?
I need the sensor and trigger wheel from one. If you have a set or two and want to part with them, let me know and your price, too.
I'm assuming you're going to use them in some other t-case? I might be able to grab one if I hit the wrecking yard today.
Yep. Wanna use them in the '87 V30's 205 t-case for the 4L80E swap.
I have to of the rings already out of cases. One is from a 241 case and the other i believe is from an s10 transfer case. They both the same size and spline. Just the s10 one is only has splines on 3/4 of it.
You mean the S-10 splines are stripped, missing or just different than the 241?
Thanks for the offer guys but another member sent a PM and sold me a true 205 sensor and wheel from a '91.
