I need the arm that connected to the transfer case for the NP 241C. It is different from the 208 because it was clocked about 20 deg from how the 208 is. Thank you for your help!
I think I may have misunderstood what you needed. I have the rod that goes between the shifter and the t-case. You need the lever on the t-case though, right?
i need the arm directly bolted to the transfer case. it has the rectangle cut out of it at the transfer case end and a circle out of the other end for the linkage.
I've got one. The bushing that the rod connects to is torn on one side. You may be able to use the one off your 208. If you still want it, how about $20 shipped?
