Make the world's first 4x4 Corvair..
Mount a Dana 44 front axle up front,a 14 bolt in the rear,and put the engine in the middle with the crank facing the doors--use another differential as a transfer case to send power to both axles..
Some of the bog buggies are made that way--they use typical 4x4 solid axle up front,and a rear diff from the same vehicle,and use a FWD transaxle and engine to power them,mounted sideways in the center of the vehicle..
I don't think a Subaru transaxle would last long behind an LS V8..
..Mount a Dana 44 front axle up front,a 14 bolt in the rear,and put the engine in the middle with the crank facing the doors--use another differential as a transfer case to send power to both axles..
