Sold NP241 tcase, 27-spline, mechanical speedo
kennyw
@squarebody.chop.shop on IG
Stevens Pass Highway, WA
1989 version, 1- year only tcase. $250 picked up in Sultan, WA. Pics to come.
Any chance of shipping?
It is possible but likely not cheap, cheaper to a business. I will get pics and some measurements when I finish unloading tonight (haven't unloaded from Sunday's swap meet yet). I need a zip code and if it is business or residential to check shipping.
Sure thing, my buddy has a commercial address I can ship to. Zip is 89146
Looks like it will run around $100 for UPS ground (estimated 24 x 24 x 18 inches at 120 lb). It would add cost if I had to build the crate but I have some left over from some surplus auctions I can check to see if they will work. I still need to unload it from the swap meet to get pics.
Ok, that sounds very fair thank you.
What's shipping to 38340? I'm tempted if I can find an sye housing to make up for the cracked housing.
yeah, that's a major bummer. these are getting harder to find, and if a driveshaft bucked or dropped hard enough to break the speedo housing - what else is wrong in there? bent shafts and damaged bearing pockets?
Collision damage from a rear end impact can drive the shaft forwards breaking a case.
And, aggressive removal can break parts.
Time for a good sandblasting & Tig welding
