I have a 89' K5 Silverado Blazer 4-Wheel Drive Gas with an OHV 8V 350 cid engine and automatic transmission.
It has the standard transmission TH700-R4 and standard transfer case NP241(see pictures).
I have today started hearing a clicking sound when driving. Same sound as if a small stone is pressed into the tire.
Having the transmission in 'Neutral' and raised the vehicle in the back. I can hear the clicking sound, when I rotate(forward or backward) the tire. The clicking sound is coming from the transfer case to my best judgment.
Observing the rear drive-shaft when rotating the tire, I can hear the clicking sound two times, when the rear drive-shaft is turned 360 degrees.
The transfer case is correct filled with lubricate to the lower level of the filler hole (I have just checked).
Yesterday I had pulled and pushed the speedo cable to be able to remove and install the instrument cluster again.
Anyone experienced same problem or having an idea to, what is causing the problem.
