07coupegt
Registered Member
Does anyone know how the 90 degree fitting for the vent line on an np241 is attached? My case is leaking where the fitting ataches to it and the fitting seems loose. I don't want to pull the case apart if I don't have to. I don't think that the fitting can be threaded in, because it will hit the case if you try to turn it.
