I'd really rather not revisit the fluid capacity debate on the 241, but I need to do a couple of things to it anyway, so if possible, I'd like to resolve the venting fluid issue while I'm in it. I already have a "fix" that works, but it's external and it adds a bunch of junk and places to leak. Plus makes checking fluid difficult. And if it's difficult, I'm less prone to keeping up on it.
GM/NP knew there was an issue, as evidenced by the early/late case castings (apparently this change happened when they went to IFS so I/you can't just get an updated case):
I have to drill and tap the vent since it's no longer a snug press fit anyway, any ideas on how to shield the vent from the fluid that gets thrown on it?
It looks like there is enough meat there on the inside to tap a hole for a 4-40 or 6-32 screw. Maybe bend up a metal deflector and use the screw to retain it? A "U" shape perhaps?
Somewhat on topic, does anyone know why the vents are so large on any of the components? In this component, it doesn't seem like there would ever be a large/rapid enough temperature change to necessitate such a large opening. I've seen people tap it and use a 1/8" fitting, I'm assuming they don't have issues with fluid being pushed past the seals.
