Mkuhn138
My K5 is being built as a prerunner with TTB suspension, and consequently need to swap out my TC with Drivers-side drop unit. It's going behind a 700r4 with hydraulic lockup. I will really only be using 4x if I get stuck, or possibly if I'm on Icy roads in the winter. I was originally planning on a 241 but really am intrigued by the idea of the 243 due to the electronic shift - mainly bc I prefer to not have a shift lever; I'm fabricating a custom center console prefer to build it as clean as possible. My concerns are:
-Will a SYE kit intended for a 241 work on a 243?
-Will the 243 work without an ECU or factory gauge cluster?
-Is this an idiotic idea?
I know the electronic shifters/encoders go out from time-to-time, but am not so worried about that. Also, will not be towing this truck so Neutral is not much of an issue. I just don't want to introduce something that's gonna need a stand alone module or a bunch of oddball wiring. Literally all of the factory engine control and gauges are gone and I'm running a Holley ECM and other stand alone equipment. Any insight is much appreciated.
Yes, this is very idiotic. Don't know why anybody in their right mind would want to swap on electric shift
. Prerunner in California explains a lot though
