supergeess
Newbie
This might be a dumb question. I have a 89 NP241 that was originally cable driven speedo output. I needed an electric VSS signal for my 2005 6.0 vortec/4L60E 4X4 conversion. So, I just had the guy who installed my SYE swap out the cable driven output for a used electric VSS he had sitting around. My question is: was there supposed to be a reluctor ring installed along with switching to the electric VSS? My rig runs fine, but sometimes, randomly, doesn't shift properly out of 1st gear. It will run perfect for 2 weeks, then randomly begin not shifting properly. Also, once I drove on a highway and got up to about 55-57MPH and the speedo dropped to 10 and 14 MPH, but he rig was still running fine. Once I got off the highway, it began the shifting issues. I have hooked up a scan tool and get P0719- Brake switch, but when I check everything, there is no problem with the new brake switch, wiring and power. Just rying to get some answers before I start taking things apart. Any help is greatly appreciated.
