NP241
stylin6
Kansas
Does ORD sell a fixed yoke conversion for the NP241? I am putting this in a 70 Suburban and need to convert both the front output shaft and the rear, to fit the the fixed yoke axles on the truck. Thanks.
I don't know if ORD sells it but Jesse at high angle driveline does. The NP241 uses a sagina front shaft whereas the 203 uses a spicer shaft so you will need to do some driveline work.
i think the fronts are interchangeable . mike<borregoK5 >
has a 203 and it has a saginaw flange. if it is anything like a 208 either it should be swappable to almost anythign with the same spline count ,-32 i think ?
