NP241c shop/repair manual
cuervo
Runn'n down a dream!
Sweet Home Alabama!
Does anyone have a link to a Chevy NP241c repair manual?
I've look high and low on the net and have only found one $36 bucks for a pdf that I know is out there, freely.
I need the case bolt torque and pattern.
Thanks.
The service manuals in the link in my sig should have that info. Did you already check those?
Thanks Dorian, I had not check those yet. However, a quick glance and under Tcase it only has 208. I would assume the case torque is the same for a 208 and the 241c. Those are listed at 23 ft lbs.
Online resources such as Torque King 4x4 and DIY Repair Manuals can provide you with an NP241C shop or Cupra Ateca Workshop Repair Manual. You can also search for original or aftermarket manuals for GM vehicles from 1988 to 2000, such as Haynes or Chilton, which are available from online retailers or auto parts stores. You can also look for exploded diagrams, which display the internal parts of the NP241C transfer case, for a rapid visual.
Do you like gladiator movies?
