Bigredburb_Tio
Registered Member
Hi I have a question about the 241c transfer case that went into the 88-91 burbs and blazers. I have a 90 v1500 that has a 700r4. While driving down the freeway the tràns and the tcase both cracked in half a month or 2 ago and have been struggling to find a transfer case for it since then. I found and pulled one today. While pulling it I noticed that it has a cable speed sensor as apposed to the electronic one that is currently on my truck but just figured I could maybe find some help online to converting it, but to no avail. It seems that most want to go from the electronic to mechanical not the other way around. Am I out of luck for converting it. Would it be as simple as finding someone who is selling just the tail housing from a electronic tcase or will I need to be finding a different case. Could i put a metal/plastic cap in it then run it since to my knowledge it is the vehicle speed sensor? Then just run a GPS speedo while inside the cab till I could get a ls swap going. There is a second burb at that junk yard that has has the set up I need in the 91 so I might be able to go back and pull that one but if I could avoid it I would like to since it's on the more expensive side for a junk yard tcase and it's about a 2 hour drive from me. Thanks.
