Does anyone know the part number and/or where I can get the pigtail for a 1991 Suburban VSS pigtail and 4WD low signal pigtail? I'm about done with my harness and this is what I'm missing. It's a 2003 2WD harness.
possum
Are you averse to used? From what I've seen it appears GM went with the same VSS connector (even the VSS itself seems the same) on pretty much everything with a t-case initially. The S10's I looked at have the same connector. Wrecking yard probably wouldn't be tough to find them.
4WD indicator is a two pin weatherpack, correct? Not aware of any pigtails made specifically for that application, but making (or finding) one should be somewhat easy. Not sure if the S10's also used that same connector.
Don't have any part numbers, you might be able to find the VSS connector in the Delphi catalogs, but then you've got to get the pins, seals, preferably a crimp tool (if you don't have it already) etc.
Anymore I prefer to just make the things. I don't like solder or crimped joints, but sometimes finding the correct connectors is difficult. Mouser.com is my go-to, but you either better know exactly what you are looking for (IE, Delphi part number) or prepare to spend a bunch of time there.
But their shipping is extremely reasonable, and I've yet to find any other vendor selling the same things for less.
