NPT to farrel fittings ??
cuervo
Runn'n down a dream!
Sweet Home Alabama!
I want to add a cooler that has 1/2 NPT, so I'm looking for I guess 1/2 NPT to 3/8 farrel fitting. Who makes them?
Can I assume that you are talking about the double flare style fittings that the stock hard transmission cooler lines use to attach to our radiators? If so, you can buy a fitting like that at Napa or just about any speed shop out there that carries Areoquip or Russell fittings
Yup, just got back from Napa. Had to use a 1/2 NPT reducer then a flare fitting.
Thanks.
Did you get what you need? If not i can come up with the correct stuff to make things work.
Thanks Scott, I did, from Napa.
Got a 1/2 NPT reducer to a fitting that has 5/16 flared on one end and NPT to fit the reducer. Now just waiting on the new tranny and the cooler.
Whoops.:o The word "farrel" in the first post confused me, I thought that you wanted to go from the flared line are a hose.
Yeah, I ask for the wrong thing. It's not even ferrel its ferrule and that is a comperssion fitting unlike a flared fitting which is like a brake line.
Thanks for looking though! :bow:
