Nut and bolt check
70jimmy
3/4 ton status
Staff member
Moderator
Released from Pueblo, told I belong in Southpark
Just finished going through the jimmy for my Pre Blazer Bash nut, bolt, and fluid etc. check.
Reminder to check those steering arm bolts that hold the arm on the steering box and check the box bolts through the frame also. Thanks Jason 4x4.
My arm bolt was loose, also found some loose engine crossmember bolts. a Tcase adapter bolt missing, and some loose slider to frame bolts.
Check the nut behind the wheel?
Joking aside, check U joints as well
Yep u-joints were fine. Replaced my spare axle shaft that is in the truck since winter, had to get a new stub and u-joint for it so of course I bought a few spares.
As far as the nut behind the wheel, look at what is below my username...
I've known you long enough not to need an explanation, but at least you warn the others!
Leaving tomorrow?
