nutin
Metrodps
Strange but nice guy
Author
earth
Those brackets look like they have the right curves to fit a K5. The wide curve would be the lower and the tight curve shout fit up high on the quarter/bedside.
The very first unit for sale I believe is for 1st generation Blazer/Jimmy trucks. I'm pretty sure I bought that exact unit from JC Whitney and put it on my Blazer. In the picture the inner threaded brackets are not shown so I don't know if it was complete. In the eBay add one you can see the two inner threaded brackets. They go inside the fender and the one with the 1/4" round rod on it is the upper bracket. The rod was to help you put it up in the very top corner of the rear so you could put the bolts in. Once it was in you could twist the rod off the bracket to remove it.
Looking at the top one again, even though the brackets look the same as what I had, the main bracket is even and not tapered like the second and last one pictured. It is too narrow at the hinge end to mount on a blazer rear body and is either a Scout or Jeep unit.
i always wanted one. seems like a nice deal! i,m not going to bid ,i don,t have a ebay or paypal acount. and i don,t want to raise the price. kennyw if you want to resell i could be interested. metrodps nice built you got. keep posting tire carriers maybe someday i will be able to get one :rolleyes:!
