Nutsert tool ????
BoondocK5
Chevrolet Bone Collector
Author
Salt Lake City, Utah
Can it be used with the nutsert placed in it backwards?
Reason I ask is I want to bolt something under the cowl directly in front of the windshield, on the firewall. I can’t get the install tool into that cowl area. It just won’t fit. I have the dash completely out of the vehicle, and can easily reach the backside of the firewall inside the cab.
Can I install the nutserts with them place backwards in the tool? Will it still crush the nutsert correctly, actuating it from the back side?
I don't think that works. The first 1/8" or so is the crush area, that part is un-threaded and has a shoulder that ends up against the sheet metal. If you put it in backwards the tool can't crush the insert, there aren't any threads to grab.
You could put an insert in from the back side but the insert would not be flush, the body would be sticking out.
You can install them with a bolt, nut and wrenches but it is very difficult to keep the insert from spinning. I have had very little success doing it this way but there are several videos on YT showing ways to do it. This guy uses an impact which you wouldn't have room for but in theory it can be done with wrenches.
That is what I was going to suggest
Making sure the hole just barely fits the insert helps the knurl grab. You can also add anti seize or oil to the bolt to help it turn without spinning the insert. 3 or 4 hands helps too.
McMaster sells a wrench-driven install tool that is a step above the nut/bolt/washer. They are relatively cheap and effective. I have 5/16 and 3/8 tools from them that I can let go.
I have a couple of these. They work well. Esp for the large sizes
Thanks fellas!
My preferred size of nutsert is 1/4x20. I’ll buy one from Mcmasters. I’m sure I’ll use it more than once.
