gonefishin
my 700r4 has messed up for the 3rd time and i am tired of messing with it so here it goes
i found an early model nv4500 that already has the advanced adapter bellhousing for a good price but i don't know if i want that low of a first gear or not should i keep looking for the later model is there any other advantage to the later model
what is the length difference between the nv4500 241 and a 700r4 with the 241 are they close enough that i won't have to modify my driveshafts
and since it already has the aa bellhousing which slave do i use and will i have enough clearance with my front drive shaft i only have a 4 or 6 inch lift not sure which
and i have a flywheel from a half ton pickup with the 5 speed getrag trans will it work or does it have a special flywheel and clutch
the more i read up on this the more confused i get lol
thanks
thanks
