CO NV4500 and/or 85-91 hydro clutch pedal assembly
Kay86K5
Emmett, ID
Hey All,
I am looking to do a NV4500 swap and looking for the trans itself (I am not pickly on the year as I know the earlier years had the lower 1st/reverse gears, but this is going into a tow rig, so the later years with the taller gear is fine with me). If anyone has one they are looking to get rid of, hit me up as I am currently cruising craigslist constantly looking for one :)
Also, my truck right now is an auto with the TH400 so I am looking for the 85-87 pickup or 85-91 burban, blazer, or crew cab hydro manual clutch pedal assembly. I know these are kinda hard to come by but thought I would put this up here to see if anyone has an extra setup....couldn't hurt huh?!?
If you have the whole master/slave/resivoir setup too, that would be cool, but if not it looks like you can purchase these from LMC new for not too bad of a price. I am also planning on the AA adapter plate and bellhousing to be able to run the 85-91 hydro setup and be done with it. So if anyone has some of the things listed above that you want to make some money on, let me know. You can reply to this thread, send me a pm or call/text 720-387-6072.
Thanks!
forgot to add, i do have hydroboost brakes....I know that makes a difference when it comes to the pedal assembly
I don't have a lot to offer but if you do have to buy the reservoir setup from LMC they don't have the rubber bladder that goes inside the cap. I found this one, its for a J**p application but it works. Some people say you don't need it, but for $20 bucks it couldn't hurt. One last thing, I have had good luck on craigslist by searching for "Chevy truck" seems like people parting out 2wds are not as high on price as people with 4wd.
Clutch Master Cylinder Reservoir Cap and Bladder Mopar Part# 4741671 Link ($19.43)
Good call. I just contacted both of those guys (first two links are the same dude). Thanks man!!!
Hopefully they respond back to the text soon, haha. If not I will call them in the morning
Good luck! Hope you get what you need! Might also try to get that steering column if he is not unreasonable, seems like those things are solid gold.
