TX NV4500 conversion setup
mckustomfab
Carrollton, Tx
I have a Advanced adapters NV4500 bellhousing kit that I had installed on my big block for about a year and a half. I have everything that goes with it, the bellhousing, the slave cylinder mount, throw out bearing, clutch, pressure plate, friction plate, and I will throw in the master cylinder and slave cylinder. I removed these because I have started my Cummins swap. I will post some pics shortly. $450 OBO
I didn't know steel NV4500 bell housings existed. What applications used them? :dunno:
They are aftermarket. It wasn't offered as a factory option. I was going to build an adapter to go to the 4 cylinder diesel with it. Now that is sold it's sort of a moot point. I have an aluminum one that is cracked but I think it will work.
