Nv4500 fluid fill question
mrgoodwrench
Minnesota
Sorry if i have already asked this and forgotten. Should i fill the nv4500 using the factory fill and drain holes. Or should i fill it from the top through the shifter hole? If filling it through the shifter hole how much should i use? till it comes out the normal fill hole or more. Thanks mike
4qrt if i recall . Lots of guys say 1/2qrt over filled threw top to help lube input bearing .
Make sure to use SPECIFIC fluid NOT gear oil .
Honestly I prefer to fill from the shifter because of side access is generally a pain.
No one way is better than the other but higher here since you want 1 quart more than oem spec.
