I can drill a lot of holes for $400.......
Martin
Then you would probably end up with a leak
Martin
Then you would probably end up with a leak![]()
When I did the NV4500 thing what made the decision for me was having the tranny to bell bolts end up coming into the tranny from the inside of the bell. This makes them inaccessible and just as importantly, not inspect-able. Worse yet is installation issues, having to get everything lined up with the bell attached to the tranny is a much bigger pain in the ass...
All to save what? $200 maybe?
F that, I also chose the AA bell and hydro slave adaptor for $400 from Advance Adaptors. It bolts up like normal, can be serviced normally, bell bolts are external, uses all GM parts for the hydro clutch.
If money is so tight that a lousy $200 makes the decision for you, this might not be the hobby for you. Especially when the pros and cons are factored in.
Meh. NV5600's have an integral bell housing, and they make an NV4500 look like a little girl.
Martin
You should try rolling a tractor split together sometime.
Martin
Why do folks eliminate slip yokes?
If you damage the rear shaft off road, you can remove it and limp home on the front only. With a slip yoke, pulling the shaft creates a big leak if you drive it.
Maybe it's because most slip-yoke trans spec trans fluid (outside of things like the slip yoke 205's) and the thinner stuff leaks easier, but it also seems to me like the slip yokes are more likely to leak than non-slip yokes. Pretty common to always see a drop of fluid hanging off the extension housing on a slip yoke truck.
Apparently pretty much nothing needed swaps between the driver and passenger drop 241's. If it did, swapping to a fixed yoke would be a lot easier and cheaper.
