Wanted NV4500 steel bell housing, scatter shield
title says it, anyone got one around they aren't using? I may need one.
I didn't know they had steel bells for those years.
I have a few of the sm465 steel bells I think you have to modify something but I know people use them
Not sure you still need this or if this will do but I have a bell from a chevy c60.
Has multiple mounting patterns on trans side and sae pattern with an adapter plate to chevy pattern on engine side.
I can get more pics.
It was bolted to an sm465
DAYUM! That looks like a heavy bastard. Cast iron? I am keeping hope alive for a good deal on a steel bell housing but in the mean time the aluminum housing I have will work fine for moch up. It has a little damage on the cover portion over the passenger side slave cylinder but I don't think it will effect it's use.
It's a little heavy yes.:)
what was its factory app? or is this aftermarket?
Any of the GM steel manual transmission bellhousings are adaptable to the NV4500. Lakewood and a few others make them. They are just 500 bucks or more.
Any of the GM steel manual transmission bellhousings are adaptable to the NV4500..
that's why I asked what app... I don't know of any steels... everything I've ever seen was cast iron or alum...
I don't know what the application is either, I just saw one bolted up to a 2wd NV4500 in a friends diesel shop the other day on a customers truck. It was bolted to a 6.5 In a 95 3500 truck. I asked then and no one seemed to know so I thought I would look for one here. Been trying to get a hold of the owner for a week with no luck.
if ya find out, pass it along, thanks... :)
