gonefishin
i just got done with a nv4500 swap new style 96 up internal slave factory hydro bellhousing i converted a 85 up master to -3 an and a new internal slave to -3 an with a russel braided -3 an line for clutch and brake system and i am running a regular 12 inch clutch from a 91 half ton that i had already lifetime warranty so i got a new one before i put it in
now its acting like the cluch is not releasing all the way when i let the clutch out it takes off fine but after 3rd gear i can make it slip as soon as i hit the clutch pedal it disengages it i checked to see if it was holding pressure in the line keeping it open and nothing i shimmed the master away from the firewall thinking it was keeping the rod pussed in and nothing
did they change clutches with the internal slave its like the fingers on the diaphram are too long and the slave is pressing on them all the time i need help thanks
