yeah figured that out about two hours ago that sucks i have heard that the stock nv4500 bellhousing wont work because of the slave cylinder will inerfere with the front driveshaft but what if the truck has a lift
Even with a lift it's a problem. You could swap in a Ford front end, or pick up a bell that'll work for you from Advance adaptors for right around $400.
what all is involved in a ford front end swap i think i have a dana 44 out of a 70s f150 doubt its jusst a bolt in kinda though i can weld and have a plasma cutter if someone could just point me in the right direction
