NV4500 Swap
4Rohan
Registered Member
Denver
Looking to put an NV 4500 in my 77 k30. What do i need to make this happen? Currently running a 454/ 265 / 205 setup. Will the nv4500 be a direct change?
Do a little searching. It's not a direct swap by a long shot. I assume you have an sm465 and not a 265. You need to convert to a 32 spline input on the trans and need an adaptor or redrill the face of the 205. Also need to move the transfer case back the extra length. If you have mechanical clutch linkage, you'll need a new bellhousing to put the clutch fork on the drivers side or convert to a hydraulic clutch.
