MTMike
History: the 4 bolts that hold the 205 to the adapter aren't quite enough to support the weight of the 205 without an additional bracket. You need to use the factory (or a custom) mount to support the weight of the drop-side of the transfer case. I learned this on day 2 of a 7 day wheeling trip when the 205 fell off A few bolts, a ratchet strap and some wire and I was able to make it through the last 5 days of the trip without any other problems.
So I pulled my NWF doubler out of the truck to repair it. The threads on the 205 plate are buggered up pretty bad. The 203 plate is in great shape.
Then, a friend cleaned it in a roto-jet machine, and I changed the clocking configuration so that I can use all new threads but not change my transfer case clocking much if at all.
Using all clean, unused holes/threads and new, clean bolts we put it all together. The plan was to TIG weld it all together, and add a small piece of 1" bar stock on the bottom part to take some of the load of the center section bolts. However, my friend's 180A TIG didn't have the brass ones to even make a puddle in that massive AL stock. So he suggested safety-wiring all of the bolts together.
I talked to another friend and he has a Miller 251 with an AL spool, so I went to his house to give it a shot. It would stick the parts together, but it barely penetrated into the aluminum, and a light blow with a hammer would break them apart again. So he had a suggestion: Drill and tap a hole all the way through the 2 pieces of the doubler and the bar stock, and then countersink the heads of the bolts into each side of the doubler. So that's what we did.
And here's pics (hi-res available upon request)
Safety wired:
The inside of the 205 plate
The inside of the 203 plate
The bar stock on the bottom:
Hopefully, this will hold for a while
Safety wired:
