I got my nwf springless arm for crossover on my Dana 60 today and couldn't wait to bolt it up.
Got it installed and threaded the adjuster in. Threads were a bit sticky but it was turning ok. Got it tightened and torqued it to 20 ft lbs (torque spec I found said 10-30).
Kingpin was still loose and wobbly so I put a ratchet on it to turn a bit more and it wouldn't budge. Loosened it off about 2 turns and it got stuck. Tightened back about 1/2 turn and it got stuck. Tried to back it off and rounded off the hex head on the adjuster. Now it's stuck with no way to turn it.
Thought about heating the arm and trying to turn it with a pipe wrench to get it out but I don't want to screw it up any worse.
Should I just try to get a replacement arm? Did I get a blem or is this something common? Search didn't bring up anything so I'm assuming this doesn't happen too often.
