k5 krawler 50
Well i'm trying to button up my steering and i went to install my drag-link and the tie-rod end i'm using (ES2010R, which has the same dimensions as ES2234R just has less threads), but the pitch doesnt seem to line-up w/ the pitch of the hole in the steering arm. I thought that these steering arms were drilled out for chevy tie-rod ends, but i guess i was wrong. Any how, i was wondering what other tie rod ends could i use or is there a drill bit i could use that has the same pitch as the tie-rod end? I dug up an old picture that illustrates some numbers that relate to the pitch of the tie-rod ends which is attached below. I already have my draglink welded up and set up to run a tie-rod end with a 7/8" w/18tpi, so if you guys could help me out here that would be awesome, thanks and i hope everyone has an enjoyable Christmas
