No problems at all. And there is no possible way to make it any cheaper.
Cool. I think I have some ratcheting straps laying around in the garage.
I think I may do it like that up on the rear DS wheel well until I get some more $$ to build a cage for it like I want to.
I can't speak for cbbr, but he inspired me to do something similar. I've recently completed mine (well, I have some stuff I want to add) with some modifcations.
I purchased a york from a member here, with brackets included. I also picked up a small tank that used to be a part of an air compressor kit... no pump or motor, but it had the pressure switch, regulator and manifold. Instead of using ratchet straps, I made some clamps with some strips of aluminum as you can see in the pictures... what you see is basically my first test of the system and I've since cleanup a lot of the wires and connections, but you get the idea. I've got a rocker switch in the cab that matched the ARB locker rocker (hehe) which feeds power to the pressure switch.
I plan on adding another tank to the rear of the vehicle, not sure where yet. Then I might add quick disconnects in some, if not all of the wheel wells.
