BIGCHEVY4X
Registered Member
I have an 89 blazer TBI and im trying to check the codes and view some data tables. I tried a MAC Scantool with the proper obd1 adapters and power plug and it wouldn't communicate. I also tries a nexus scanner with the same result. So i ordered a cable from http://www.aldlcable.com/ and tried to use the winaldal program on my laptop and still no data. The blazer is in rough shape so i want to verify the aldl port is wired right and have the proper voltage and all that. Where should i start? Thanks
