This problem is with my Dodge but since pretty much all hydroboost setups works the same I'll ask here. Might help some else in the future.
The truck has 209k on it. I've changed the steering box once at about 140k due to it leaking. The current box is starting to leak, I noticed it this weekend. Ps pump is original as is the booster.
The issue is when slowing down and then turning left, the wheel barely wants to turn at all. Like almost locked up not turn. But if you do the same and turn right. Everything works nice and smooth as it always has. Driving down the road and maintaining my lane uses the same effort is always has.
My first thought was the box going bad. My dad had a similar issue with his work supplied GMC van and it was a problem with the booster.
I know the steeing box has a slight leak and it's getting changed regardless. But I want to be sure about the booster. They're not crazy expensive but it's an pretty involved job to change it out.
Thanks.
Thanks.
