I changed the pics to jpegs, should enlarge.Can't see any of the info because it is way to small and when you clik the pic it gets smaller
$OD was used on 1995 models. I have not been able to find a $OD schematic with the 700R4. What I was able to find, are the posted schematics. The 4L80E VSS is going to pins F2 & F3. The 4L80E does not show a VSSB between the PCM and VSS. The 4L60E is using pins F12 & F13 which are from the VSSB, which is getting it's inputs from the VSS.but those pics are for a 1995 C1500 4L60E not a 700R4.
What does "$OD" mean?
I really can't answer your question but are you trying to put a 700R4 into a truck that came with a 4L60E? The 4L60E and the 700R4 aren't the same.
I'm trying to upgrade a newer computer, $OD, into an older TBI vehicle that has a 700R4.
dave w
